ifoundthetao
Okay, so I am running XP PRO SP2 on a Gigabyte GA-8S661FXMP-RZ, and lastnight I was using GrabIt so I let it run while I went to sleep. I went to check on it this morning, and my computer was logged off (this is odd, because its in my room and nobody came in or anything). So when I logged back in, GrabIt had stopped about a quarter of the way through, and my resolution on my screen was different. So when i tried to change it back (its usually at 1280 x 1024), the screen was acting like it wasnt a native resolution. Like, the whole screen wouldnt fit on my monitor. So if i wanted to go all the way to the right of the screen, I would have to put my mouse on the far right, and it would scroll over. Same thing with the top and the bottom of the screen. This is the same for all of the resolutions, until 1024x768. I checked my drivers and I'm pretty sure that they're okay. But maybe I am not doing something properly. Okay, well I just want to get my computer back to the way it was before. Thanks in advance.
Tim
Tim
