Resolution and how it LCD size effects...
imported_Indohottie
Hey
Looking at a LCD tv with resolution 1280 x 720..
I think it can do a little better link is here:
http://www.viewsonic.com/products/tventertainment/lcdtv/n2750w/
Can you help me understand is 1280x720 look different on a larger monitor? I dont know much bout resolution other then the higher the numbers the more fine the detail ont he screen.. so my question is will 1280 x 720 look more fine on a 27in vs a 17 in LCD?
Also input on your thoughts on the viewsonic above would be cool..
Frank
It will look coarser on a big screen with same or smaller res. 17" LCDs typically have 1280x1024. A 27" at 1280x720 is very coarse because the pixels have to be bigger to be that resolution, whereas on a 17" they have to be small. I'd recommend a higher resolution. Nothing other than 1280x720 or 1920x1080 though if you're viewing HD. If you can't afford 1080, get the 720. If you're viewing 4:3 aspect ratio analog TV, get 1024x768 or 2048x1536. Divide width by height and make sure it equals 4/3 (1.333) for analog or for 16:9 HDTV make sure it comes out to 16/9 (1.777).
Originally posted by: Indohottie
Hey
Frank
It depends on what you are looking to do with the device. There are many factors playing into the sharpness of your screen. For instance, when you play on a 17" monitor, you are probably 1 foot away. Thus, a .25 dot pitch is noticeable if you look for it. Now, with this TV you are looking at, the dot pitch is .5 I believe, twice the size. But will you be 1 foot from it? I hope not.
I have a Dell 30" LCD that does 1280 X 768 and I absolutely love it. In fact, I cannot even stand to be on a 17" monitor anymore. Everything seems so small... I sit about 3 feet from my monitor and play WoW all the time. It looks wonderful.
So the question you have to ask yourself is the following:
1. How far do you plan on sitting from the screen? The farther away the sharper the image for the most part.
2. What do you currently use for a resolution? How far away are you from the monitor?
3. Do some math with the numbers. I did some simple math from taking my 19" CRT at 1024 X 768 and sat close to it and then sat far away. I got an idea on how the picture turned out. I did the math to figure out what a large display with that same resolution would look like, and how far away I would have to be from it to look sharp.
So keep in mind that distance is everything... I can only comment on my display, but I enjoy mine quite a bit. WoW plays wonderfully with everything cranked up at 4X AA and 16X AF with distance viewing maxxed.
Just my opinion... Another suggestion I have for you is to go to a Dell Kiosk, normally found inside malls. They have both their 26" and 30" LCD's in display to view. Take a look at them and make a decision for yourself.
