Resetting CPU to default CMOS values.
Telstar
44
Tried to overclock my FSB to 133 on my KT7A/AMD 750. System won't post. Is the best way to get the CMOS to return to the default 100 on the FSB just to remove the CMOS battery backup or is there a better way to get it reset?
max105
1,139
there should be a jumper on your motherboard that you can set to reset your settings to default. you can try that too
Buratino
25
Read your manual. There is a jumper which allows you to clear CMOS. Just short pin2& 3 for a while and return it to pin 1 & 2 then boot again.
Killrose
6,230
8
Before you attempt the 133MHz bus change, set your cpu core voltage to max (1.85) .
