Required Power Supply for new system?
Shaitan00
I am in the middle of building a new system (looking to build a monster/killer system). I've pretty much decided what components I want to get, the only problem is I have no clue which Power Supply is needed/recommend. I am not looking to be cheap (money isn't a huge issue) but still wish to stay resonable.
My new system profile is the following:
[Profile]
CPU: INTEL Core 2 Quad Q9450
MOTHERBOARD: Asus X48 DDR3 (still debating on which one)
VIDEO: ASUS/SAPHIRE 4870 (Arctic AccelS1 rev2 with dual fans)
RAM: 2x2G OCZ DDR3 PC-12800 1600 MHZ (Platinum or Reaper HPC)
HDD: 4x Western Digital SATA2 500GB
2x Western Digital PATA 320GB
Case: Full ATX Tower with 5x 120mm & 1x 200mm fans
Question is...
a) how powerfull of a Power Supply do I need? 650W? 700W? etc...
b) what are the prefered manufactuers & models?
Any advice would be greatly appreciated.
Thanks,
Corsair TX650 (non-modular) or 620HX (modular) would be my recommendations depending on whether you care about having modular cables or not.
Well you surely don't need anything more than 600W total, but you may find a deal on on another PSU with more wattage than that.
Anyway I believe the most preferred brands would be:
Corsair
Xigmatek
Enermax (possibly, is still TBD; [IIRC liberty units kept dying randomly like a year later, gotta wait to see if the new lines suffer the same fate])
Seasonic
Silverstone(some)
Coolermaster (some)
Antec
Etasis
FSP (some)
PC Power & Cooling/OCZ
Anyway that should be enough to have you looking, I'm sure others will add more brands.
