Hello fellow pc enthusiasts!
I am about to build a pc for the first time. I have spent a long time researching the majority of components over the last few weeks. As I have no experience or knowledge in pc building, I require professional advice in regards to compatibility and optimisation in relation to all of my selected components. As this computer including its peripherals are going to be such a large investment its crucial I receive expert advice and feedback based upon the computer components have selected/not selected.
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
General pc usage as well as a lot of word processing, high quality music playback, programming and playing the latest pc games.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
I see no need to provide a budget as I have already selected the majority of my components. However I should mention that if you recommend me a replacement for one of my selected components please choose a replacement which is close to the price of the component which I listed.
3. What country YOU will be buying YOUR parts from.
The United Kingdom.
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
We can't be expected to scour the internet on your behalf, chasing down deals in your specific country... Again, help us, help YOU.
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
I will only be using an ASUS motherboard, Intel processor and Nvidia graphics card.
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
No.
7. IF YOU plan on overclocking or run the system at default speeds.
Overclocking is something I will consider in the next 1 3 years, so future proofing against overclocking would be wise.
8. What resolution, not monitor size, will you be using?
1920 x 1080 at 120hz 144hz. Specifically either one of these two monitors:
http://www.amazon.co.uk/BenQ-XL2420...TF8&qid=1409108956&sr=8-2&keywords=benq+144hz
or
http://www.amazon.co.uk/BenQ-XL2411...TF8&qid=1409108956&sr=8-1&keywords=benq+144hz
9. WHEN do you plan to build it?
Note that it is usually not cost or time effective to choose your build more than a month before you actually plan to be using it.
I plan to build the pc during the next month although the graphics card will be added a bit later, the gtx 800 series is expected to be released in September. As I may either be purchasing an EVGA gtx 780 or gtx 780ti I believe its wise to wait for the release of the 800 series, this will hopefully bring the gtx 780 and gtx 780ti price down and also to see what the 800 series offers in terms of high end gaming.
X. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
Im only aware of Windows 8.1 to be necessary at this time as this will be the operating system of my choice.
Operating System Windows 8.1
Chassis MATX Xigmatek Aquila
http://www.overclockers.co.uk/showproduct.php?prodid=CA-083-XG&groupid=2362&catid=2278
Fan controller I do not know if this is necessary or where it is connected. I
would like to be able to control the speed of the fans.
Case front fan 200mm spectre pro 148.72 CFM ±10% http://www.overclockers.co.uk/showproduct.php?prodid=FG-063-BX&groupid=701&catid=2331&subcat=2335
Case back fan - 140mm Noctua NF-A14 IndustrialPPC 3000RPM PWM Airflow: 158.4 CFM http://www.overclockers.co.uk/showproduct.php?prodid=FG-027-NC&groupid=701&catid=2331&subcat=1816
Case top fan 2 x 140mm Be Quiet! Shadow Wings Fan PWM
http://www.overclockers.co.uk/showproduct.php?prodid=FG-014-BQ&groupid=701&catid=2331&subcat=1816
DVD-RW drive I would like the ability play CDs on my computer and Ive also read that OS installation is easier with a DVD-RW drive. However Im not willing to sacrifice performance in relation to gpu, cooling etc for the DVD-RW drive.
Motherboard - Asus Maximus VII Gene Z97 (Ive read that this does not include SATA express, Im unsure how I can resolve this issue or what exactly SATA express is.
http://www.amazon.co.uk/Maximus-VII...UTF8&qid=1409255492&sr=8-1&keywords=asus+gene
CPU Intel i5 4690k
http://www.amazon.co.uk/Intel-i5-46...?ie=UTF8&qid=1409255617&sr=8-1&keywords=4690k
gpu Will have at least 3gb of vram, the gpu will either be the gtx 780, 780ti or possibly the new 800 series if it provides similar performance.
Ram G.Skill TridentX 8GB (2x4GB)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-080-GS&tool=3
SSD - Samsung 840 evo 250gb 2.5inch Basic SATA ssd
Speakers - Harman/Kardon Soundsticks III
Method of internet connectivity - Cat6 Ethernet cable
Power supply Need expert advice on what power supply to buy I do not wish to save any money on purchasing the power supply, I would like the most reliable and efficient power supply possible.
I would like to thank you in advance for your time and help 😀
The United Kingdom.
No.
or
CPU Intel i5 4690k
