mammothbaby
Hey Folks:
My three year old Thunderbird system is in its final throes, and I've thus decided to try to build my own system. Many of the components from my old system are still usable (NIC, hard drives, RAM), and I've decided to buy all of my other components from NewEgg (seems easiest). I'm looking to build the system for around $500, focusing on upgradeability and cost effectiveness. I don't need a bleeding edge system -- just one with lasting power (okay, okay, and it should be able to run HL2 and Doom 3).
I've decided on the Athlon XP 3000+ for my processor, and a Sapphire Radeon 9800 Pro for video. For a case, I've gone with the Antec Black ATX Mid-Tower. Other components going into the system: Lite-On Black 52x32x52x16 Combo Drive, 1 gig of PC2100 RAM (from the T-Bird system), 160 gig HD (Western Digital 7200), 40 gig HD (Western Digital 7200), and maybe an Audigy 2 ZS.
My knowledge of hardware falters when it comes to motherboards, so I need some recommendations on what kind of MB to combine with this processor/video card combo. As you can see from my other selections, I'm trying to find the best combination of price/performance, but with the added factors of stability (very important) and upgradeability (for the motherboard). I won't be overclocking anything in the system, so heat and OCing shouldn't factor into your recommendations. Also, would you recommend buying a 3rd party soundcard, or do the onboard sound solutions on new motherboards perform well enough?
Thanks in advance!
Aidan
UPDATE: Thanks to mechBgon for pointing out that the Athlon 64 2800+ is only a few dollars more than the Barton. Looks like I'll be going 64 after all. I still need motherboard recs for the 64 though...
Thanks in advance!
Aidan
