Reputable laptop battery replacement?
Interitus
Have a Dell Studio 14z and my battery is starting to go.
Can anyone point me toward a place that sells either genuine OEM batteries or quality replacements?
As long as it works as well as the original, is reliable, and doesn't set off Dell's ridiculous "This is not an OEM" crap, I'm not picky.
If it matters, battery part# is N672K
Only original holds power well, aftermarket are often inferior cells.. I did have good luck with some ie AGPtek, but still I would not recommend them unless you don care
I dunno. I got a generic replacement on ebay that works fine. I did however buy one with more cells so that may be part of the reason.
