I posted this in "general hardware" earlier by accident:
Someone actually responded and told me to take out the RAM and see if the mobo gives the "no RAM detected" sound. I got nothing, so I assume that my mobo is fried. If no one disputes this conclusion, then I guess I'll post in the other categories for a new mobo and case 😀.
Here's the situation:
When the computer turns on, the monitor doesn't do anything. The monitor works fine, and I've swapped video cards to test that possibility.
My guess is that the motherboard is dead. Apparently, the computer started getting BIOS errors at start up (blue screen as the first thing he sees) several months ago. However, it happened 1/2 times, so my brother lived through it by just restarting (since he leaves the computer on normally anyways). I did not get to read it (because I can't now), but I assume that it also relates to the motherboard performance.
Lastly, the computer was extremely dusty when I took it out to clean and test it.
What do you all think?
Thanks,
qpwoeir
extra info:
I forgot the name of the mobo, but I can find it if you need it. It's a socket 939 MSI model if you need a simple reference. It has a tiny fan on it that stopped working, but it stopped working over a year ago I think (so I do not believe it would be relevant).
Everything else is functioning fine. The only weird thing is this sound that I cannot locate. It seems like it might be the hard drive skipping, but even that wouldn't stop something from appearing on the monitor.
Thanks,
qpwoeir
extra info:
