Reported fan speed jumping back and forth....
CdnAtWork
In both MBM5 and Asus probe, the Chasis fan speed is being reported as constantly jumping between 0 and 168750 (not a typo). obviously the fan itself is not actually doing this. Should i keep using that header to power the fan or use an adapter and a 4pin molex? It's a rear exhaust fan that's plugged into it.
Thanks for any input!
Cdn
Hardware:
Lian-Li PC-61 Black Anodized Aluminum Mid-Tower with 4 Vantec Stealth 80mm Case Fans (2 front intake, 1 rear and 1 top exhaust)
ASUS A7V600 400FSB, SATA, Gbit LAN 6.1, Audio, 8xUSB, With Bios Rev 1006, VIA_Hyperion 4IN1_V451v
AMD Athlon XP 2500+ Barton Core 333MHz 512KB L2 Cache (overclocked to 3200+)
Vantec Aeroflow Heatsink with Arctic Silver 5
2x Infineon 512MB PC3200 400MHz DDR CAS 2.5 Memory
Sapphire Radeon 9800PRO Atlantis
Maxtor Atlas 15k-36GB on LSI 21320 Ultra320 SCSI PCI card
2x Western Digital SATA 160GB 8MB Cache 7200RPM
LG CD/RW 52x32x52
Vantec Stealth 420W PSU
Viewsonic 19" G90FB PerfectFlat
