The Dancing Peacock
My bed sags, and it sucks. I have back probs, so I gotta fix it. The way it holds up my mattress is with about 20 or so 1x4 wooden slats that run the width of the bed. They are all attached to each other by a piece of fabric, so itis kind of a sheet of plywood slats that run from the head to the foot of the bed. The slats sit in an L shaped bracket that look just like the railing from a generic bed frame for a mattress/boxspring combo.
There is no support in the middle of the bed at all, pretty much only the wood, which is now almost 10 years old, and the sag has gotten out of hand.
I was thinking of pulling out the slats and putting in a sheet of 3/4" plywood under the mattress. Don't tell me it'll be too hard, because I slept on bunks made from plywod and 2x4 for 2 years. , no problems.
My question is, can I get a sheet of plywood the size of a full bed without having to put two pieces together? If I do need to put 2 pieces of plywood together, what's the best way of attaching them, without having to create a whole separate frame.?
