Hello all.
I have a 4 year old Lian Li PC-65. It's one of the "older" models, brushed aluminun w/clear side panel, no "blow hole" fan, (2) 80mm fans up front sucking in air with (1) 80mm fan in the back. My current temps with my rig are around 30-38 degrees on my E6600 with stock-Intel cooler and 38-46 degrees on my m/b's passive northbridge.
I want to replace all three case fans with fans that are quieter, perhaps more efficient. The current fans are made by "Adda"...whoever they are!
They look to be held in place with plastic pins. Okay, now here come my questions:
1.) Do I simply "cut" these plastic pins to remove my current fans? Or do I need to remove them properly in order to use them to mount my new ones?
2.) I know 80mm fans have to spin fairly quickly to move enough air, but what manufacturers offer 80's that are fairly quiet? What should I be looking for?
I'm thinking of replacing the stock Intel-cooler as well with a Zalman 7700 or even FS-C77 unit. Guess I'm really looking to get as quiet as I can on air cooling...
Thanks for any tips or suggestions!
Twitch
Twitch
