- Jul 11, 2004
- 21,867
- 7
- 81
This is about a 2000 Nissan Maxima.
The car doesn't run as smooth as it used to. It has a vibration to it that comes and goes. Sometimes its there and sometimes it isn't. When you turn the A/C on, the vibration usually gets 10x worse. With the A/C on, its almost always vibrating, but occasionally it still runs smooth.
I've looked under the hood and seen that the one of the fans on the radiator assembly is really wobbly. I'm pretty sure all I need to do is replace that radiator fan assembly.
I don't have physical access to the car. Can anybody give me an idea of how difficult this will be to fix? I don't want to be taking out the whole radiator or anything like that.
Update
I replaced the radiator fan today.
I had to remove two screws to remove the air intake which was in the way and two bolts to unhook the fan assembly. After unhooking the wires and unclipping a few hoses, the fan assembly just lifted out.
I did have remove the upper radiator hose to take out the fan assembly, which resulted in me leaking about 1qt of coolant all over the the ground. And reclipping the lower radiator hose was a pain, but I got it back in eventually.
All in all, it went pretty well. Took me about 30 minutes, 15 of which I spent trying to reclip that lower hose.
Update
