I've got the ancient Netgear MR814 sitting in the center of my house. For some reason, dropage is more frequent than ever, and I'm assuming there is some new element in the house that I'm not considering that is causing it. I first toyed with the idea of switching routers, but research tells me that I'd be better off just beefing up the signal strength with an antenna upgrade.
For now, I'm chosen to use the SMC 6dbi Directional Panel (Mfg Link). It can be had AR at Outpost.com for $19.99, which is great because I need a out of the box solution that I can buy at a B&M store.
The question is, will I be penalized by the WiFi gods for only upgrading one antenna. Do the two OEM antennaes work together in some fashion? If so, how?
Also, are there any other out-of-the-box-B&M-purchasable options one might suggest of comparable price?
Thanks in advance.
Thanks in advance.
