I just bought a new HD to replace my older 80GB HD which is partitioned and holds the OS (Windows XP). I currently have a slave drive which has no programs installed on it. It only is used for storage of various things such as pictures, music, tv shows, etc. Can I remove the old HD and put the new one in its place and keep the 2nd HD without loosing the files. If so, how would I do it? Is it just a regular "plug n' play".
Thanks
Thanks
