I have an old NEC 75mhz Pentium, the hard drive broke and I was attempting to install a new 10gb HD, but I have been having some trouble. I have no problem getting the BIOS to recognize the drive, then it boots to DOS and I use fdisk to clear the partions. If I sucessfully partion the drive, the computer restarts and attempts to boot DOS. The screen says: starting ms-dos, but it freezes on that screen. I can only get into DOS again by changing the device type in the BIOS, then I can remove the partiton and do it all over agin. But even if I try again I get the same frozen starting MS-DOS screen. Since I can't get into DOS I can't format the drive or install the operating system. Any ideas?
-Thanks
-Thanks
