Replacing Fans in Lian-Li 6089?
pfastovsky
17
I have read that the fans in the 6089 boxes aren't that good. I was wondering how easy it is to replace the front fans since they are connected to the speed varying switch. People have recommend using Panaflows but I really wanted to get some light going on in the case and thought about getting the Antec Blue LED fans, reportedly they have decent airflow, light and low Db.
Any help is appreciated.
Peter
EeyoreX
2,864
Assuming the insides of this case are similar to the insides of my LianLi PC-68 case, it is a simple matter of removing the fans (they are attached with "push-pins") and connecting the new fans the same way. As far as powering them, you just need to disconnect the current fans 3 pin headers and reconnect the new fans power headers. Should be a quick job. I have two quad blue/red LED fans that look nice.
\Dan
pfastovsky
17
The Antec Blue LED fans have the Molex 4 pin. I believe that the lian-li case has 3 pin.. I guess I will have to get some connectors.
Or are there better LED fans than antec?
