Hi,
Last night my pc started making a grinding noise from one of its fans. I shut it down, unplugged it, attempted to drain any residual charge by pressing the power button a couple times, and poked around.
I tried spinning the fans by hand. Most of them spun freely. A case fan was completely stuck in place. It wouldn't spin. I plugged the computer back in, turned it on, and watched the fans. The case fan did not spin at all. The horrible noise was coming from a fan inside the power supply, which was alternating between speeding up and slowing down, almost to the point of stopping.
I disconnected the power to the dead case fan and powered up again. The power supply fan seems to be steady now, and much quieter, but still far from silent. And the noise it was making earlier has me worried that it might be damaged and not doing the job it needs to do.
I am certainly going to replace the dead case fan. I am wondering whether it is easy and worthwhile to replace the fan inside the power supply as well. The PS is a Cooler Master RP-650-PCAR. I'd have to open it up to get inside. It looks like it wouldn't be too hard to get the fan grate off. Does anyone know how hard it would be to swap the fan out after that? Is it even possible to get the right size fan?
If it's a complicated job, I'll probably leave things the way they are and hope for the best. But if it's a simple swap, I'll probably go ahead and try it.
Jim
Jim
