i have 3x19" HP LP1965 lcd monitors above my livingroom tv. i bought them used, and the backlight on one of them is very reddish.
i find in the menus that these monitors actually log the time used. so i get
brightest, awesome looking screen- 9k hours *
slightly dimmer but still white and good- 32k hours *
red, dim, crummy backlight- 27k hours
these two screens share the same revision numbers as well. its probably another reason they match up in image quality.
so basically i need to replace the backlight on one screen, but i dont know if its worth it or not.
i seems i can get a bulb for $15... but i have to take apart my screen first to measure the bulb inside. i dont need a plug n play kit, i can solder no problem. i am a union electrician for 10 years and a computer hobbiest my whole life, so i have skills.
is it worth it? anyone do it? is it easy to ruin the screen?
thanks for the replies
