My old case had an AT power switch, which is now disposed of. I want to replace it with an ATX one so it'll work with my ATX board. Anyways, I did a search about this topic. I read that I should buy a momentary switch from Radioshack so I went there today but I couldn't figure out which one to get; the Radioshack employee wasn't much help either. Anyways, could u guys take a look here and tell me which one I should use?
null
When I was looking at these switches at Radioshack, I also noticed that it's only the 'top' (???) part, it's only the switch, not the part that you connect to your mobo. What do I need to buy to connect one of these switches to my mobo do I can get my computer to work? The switches have 3 prongs on the end if that helps.
THANKS!
:beer:
null
THANKS!
:beer:
