I have a recent Powmax LP8800-C psu that states on the box "supports fan speed monitoring".
It is an ATX 350W that "complies with ATX ver 2.03 and ATX ver 1.1"
The fan inside is the psu is also a Powmax, a 2-wire FM802512M, DC12V, 0.15A, Brushless, 0209, soldered to the psu board in the box.
The psu only has a 4-pin and a 20-pin connector, besides the molex connectors that supply the power to the devices .
Where would the rpm monitoring information come from, if it indeed does, and how is it transmitted to the mobo? (The 4-pin or 20-pin connectors are the only options as far as I can tell)
This is the reason I ask:
I have researched cooling for the new P4 system I am building, upgrading from my P3. My current P3 now is without a 4-pin connector, so I just have the 20-pin to connect which is req'd. So I do not know how the fan speed monitoring of my psu would work, if it does. Is the signal through the 4-pin 12V, or the 20-pin connector on my new P4C800E-Deluxe mobo?
I want to remove the supplied stock fan in the psu and replace it with a Vantec Stealth to match the 2 others in the case for intake and exhaust. It is quiet. It definetely allows fan speed monitoring, if connected directly to the 3-pin PWR_FAN header/connector I have on my new P4C800E-Deluxe mobo.
I would like to know first how the rpm is transmitted, ie through what cable.
Secondly, is it possible that the rpm is calculated on the psu board (by voltage or something?
Because I want to disconnect the current 2-wire fan out of psu that states supports fan speed monitoring!? and replace it with the Stealth by plugging it into the 3-pin PWR_FAN.
Would this cause any malfunction in the psu, and/or would a faulty rpm psu fan rpm signal be sent to the mobo, which would cause a faulty reading, even if I had the 3-pin PWR_FAN mobo header/connector attached directly to the fan?
As a last resort, I would re-solder the Stealth onto the psu with 2-wires like the stock Powmax fan. Then possibly try to connect the rpm signal wire only to the 3-pin PWR_FAN mobo header/connector, which would be a bonus. getting the right rpm reading, if any would be a bonus too I think, but I will have this fan, and quiet IS my goal.
I need to know PDQ because I'll be shopping in a dozen hours.
