replacement thermalpad?
zeitgeistzz
my p4 has thermal greese on it but this time around i want to use a thermal pad just because it is such a pain to switich mobos and such with the greese...
hoping someone could tell me where to get a replacement pad.
thanks
cockeyed
777
You can buy them HERE. These are one time use pads and will need to be replaced any time you pull the CPU out. They stick to the CPU so I twist the HS a little before removing it, so as not to pull the CPU out with the HSF. They work ok as long as you are not going to be pulling the CPU, but IMO, it's better to use the thermal compound once the 1st pad is ruined.
