JoLLyRoGer
I have a 5th wheel that has these 2" speakers inside these plastic pods mounted to the ceiling that are part of the built in surround sound. Problem is one of them is blown and makes nothing but static.
I was thinking of replacing just the drivers with something a little bit better but try googling for a 2" full range speaker and see how far you get HAHA.
I want to keep the pods because they are specific to the trailer, so... I was thinking of ripping apart some Creative computer speakers and cannibalizing the speaker drivers since they make some that sound half way decent (if a 2" speaker can even sound decent at all); i digress.
Anyway thought someone here might be able to put me onto a good source to find some 2" speaker drivers instead... they don't have to be THX certified or anything, they just need to make noise good enough for watching some TV.
Thanks,
-JR
Thanks,
-JR
