- Aug 15, 2000
- 12,013
- 0
- 0
Suppose you have a device that uses a power adapter that outputs 5v @ 1A, If I were to buy a replacement and used a 5v @ 1.5A would it make a diffrence?
			Originally posted by: Merlyn3D
Um....you guys are mistaken....voltage doesn't destroy things, current does. Over-currenting is bad.
most power supplies are voltage sources, so the current rating is only the maximum current he ps is capable of delivering.
Originally posted by: FoBoT
yes, that is just how much it is capable of delivering. the actual current a load pulls is determined by the device, not by the power supply
so you'll just have extra unneeded capacity, no worries dude
