Replacement Motherboard for Hp Pavilion m7657c
platinumsteel
26
Hi I am looking for some recommendations for a good replacement motherboard for a hp pavilion m7657c desktop computer i have.It must have on-board video graphics and under 150US,Could be any of the top brand names....And if it's possible if you are able to determine if it would fit into the same original casing that would be great also...Thanks....
platinumsteel
26
well of-course it will be compatible cause it's the same exact thing.That is the motherboard it initially came with....That is why I want to change it in the first place it is giving heaps of problems...I would like to get another motherboard just as good that will work.
daveybrat
5,804
1,015
http://www.newegg.com/Product/...x?Item=N82E16813130120
MSI G33M-FI LGA 775 Intel G33 Micro ATX Intel Motherboard - Retail
This looks like a great board to replace yours with. The Intel G33 chipset will give you 45nm Dual and Quad-core support as well as a newer chipset that what you have now. It will fit in your case and allow you to upgrade to faster processor's down the road.
RanDum72
4,330
That looks like a standard microATX board. If thats the case, any microATX board will fit
