replacement lens caps?
troytime
1,996
Lost a lens cap today, it popped off while on a wooden bridge. It rolled about 5 feet, then fell off into a big pond.
After a few minutes of waiting, it was apparent that the cap wasn't going to float to the edge. :(
Are the generic ones on ebay/amazon decent?
I see ones with a little string attached - makes sense now :)
in honor of the cap, here's a few pics from todays trip.
(unprocessed, just resized)
http://troytime.com/july15/
dartworth
15,200
10
I picked up a few generic caps from B&H...they work fine...
nice pics btw:thumbsup:
my partner @ work loaned me an old Nikkor 20-35mm 2.8...I really need to get out and try this lens...
fuzzybabybunny
Moderator<br>Digital & Video Cameras
Moderator
Jan 2, 2006
10,455
35
I vastly prefer center-squeeze lens caps such as those made by Tamron:
http://www.bhphotovideo.com/c/..._Snap_On_Lens_Cap.html
I hate the "normal" ones that come with Sigma and Canon lenses that are side-squeeze because they are so difficult to get on and off with the lens hood in the forward position. This is not a problem with center squeeze caps. The only downside to the center-squeeze types is that they will not fit ultrawide lenses that have a protruding front element.
The center squeeze caps on eBay are really hit or miss. A lot of them have too much spring tension making them hard to squeeze. Even more have really shallow "finger wells," making it hard for fingers to get a grip on them. If you go to any camera store besides Ritz and those other cruddy mall stores, they'll most likely have center-squeeze types.
Jawo
4,125
Thats exactly the type I have for all of my lenses now, the canon ones were falling off every time I looked at them it seemed.
corkyg
Elite Member | Peripherals
27,370
239
Why the obsession with online order? Just go to your nearest camera store and look, try, select and buy. Agree about side squeeze vs. center squeeze.
Jawo
4,125
I was ordering another lens ATM. If I wasn't I would have gone to Ritz, Penn Camera, etc
Anubis
78,712
427
tbqhwy.com
im gonna second this, Nikon makes ones like this for their lenses and i went and purchased this tipe for teh rest of my lenses, they stay on much better
ElFenix
102,393
8,552
so should i put a nikon lens cap on my sigma lens on my canon body?
:confused:
ProfJohn
18,161
7
I thought you were going to post pics of the floating lens cap, I am so disapointed.
troytime
1,996
i'm actually disappointed that i didn't take any pics of it floating away :)
it was a center squeeze, but also squeezable from the sides
fatkorean
793
I got rid of all my canon lens cap... they suck. I bought either tamron middle/side squeeze ones or generic canon middle/side squeeze ones off ebay (they have the string thing attached but i usually clip those off). So much easier to take on and off especially with a huge lens hood on.
-fk
AndrewR
I bought several Promaster replacement caps from Click Camera (national chain? not sure), and they are the center squeeze type. They work quite well and are very secure. I prefer them to my older Minolta caps which have the side squeeze. Only annoying thing is they have a little loop on the side (for a lanyard) which interferes with hoods so I just cut it off.
troytime
1,996
i bought a promaster one locally, but it didn't stay on very well at all
it was odd, because it looked and felt exactly like the nikon cap
i ended up ordering a replacement nikon cap from adorama
AndrewR
Maybe Minolta lenses agree with the Promaster caps better? :confused:
Wekiva
349
I was hoping for a pic of the wooden bridge.
troytime
1,996
the bridge - this was the last shot before i dropped the cap.
i have a better shot of the bridge (from the side), but its at home
GTaudiophile
29,767
33
I replaced all my canon caps with tamron caps. They are much nicer as you can use them with a hood on. Build quality as well as tightness are both better too.
Edit: For example, Tamron 77mm Lens Cap
