replacement fan x800pro
anobium
Anyone know where I can get hold of a fan for a x800pro. In u.k mine is working but is making slight noise must be bearing, Would not ussually bother me but have just built new pc which is very quite(arctic cooling case pretty good)
Dont need heatsink just fan.
cheers
Megatomic
20,127
Why don't you try to grease the existing fan bearing. Just get yourself some 3-in-1 oil and lube it up. For many people that's enough to fix the problem.
