Replacement fan for Geforce 2?
BadThad
12,100
49
Anyone know where to buy a replacement fan for a Ge2? I don't want to try to remove the old heatsink, I'd rather just replace the fan because it's easily removed.
TheFro
68
If your Geforce2 card has the mounting holes on the corners (which I think most all of them did) I would just get a Thermaltake Blue ORB. They're cheap and cool very well, but are a little louder than the stock HSF. The stock HSF is not that good IMO, so I would just remove it. It will probabaly endup costing the same as buying a replacement fan.
Creig
13
I used a Crystal Orb on my GF256, GF2 and GF3. Good price, cools good, looks good. What else do you need in a HSF?
BadThad
12,100
49
I think this one is epoxied on. I don't want to deal with trying to pry it off since it's not my card. Thanks anyway.
acemcmac
13,712
I just pried it off :-D
crystal orb here. 5500 rpm and the loudest fan in my case. video temp delta= -18C :beer:
