replacement fan for Diamond Viper Radeon x1650 Pro
country2
598
4
The fan in my son's card is going bad and trying to find a replacement fan. I removed it and its a T & T 4510M12F. I have located some 4510M12E and same with last letter being a S but no F. Don't know what the difference is on the last letter and I figure it possible a fan design but unsure. Anyone knows what fan will work or know what the last letters mean? The closest match by looking at pictures is the EVERCOOL VC-EC4510M12S-B VGA Cooling Fan. Thanks
BlueAcolyte
2,793
You could just get another cooler, or show us a link to some pics. The main thing is that it has to be the same size and around the same power requirement.
imported_Kiwi
1,375
What he didn't say was that it just isn't that critical of a choice that you have to worry about details beyond whether it fits, and is the same voltage.
country2
598
4
Thanks for the info. Was going to take a picture of it along with posting the link from Newegg on the one I "think" will work. But camera is dead and don't know where the wife put the charger at. Anyway figure I'd go a head and order the one from Newegg as I believe its the same size and voltage per the part number. If I'm translating the numbers/letters correctly 4010m = fan size and 12 = voltage beleieve E to be fan blade design. If it wont fit due to size I'll just do some machining as I have access to a machine shop and will make it fit. Card its for is cheap so don't plan on putting too much time and money in it.
