Notepad++ crashes the video drives when using the DIFF function to compare 2 files. Is there another editor that can do this well and is a decent editor, pls no VI editor.
Well, I tend to use an editor and a diff tool, so I get the best of both worlds. If you really like npp and don't want to switch, consider something like Winmerge for diffs.
'diff' and 'diff3' are command line GNU tools. GNU 'emacs' is a behemoth of an editor, which includes an "ediff" mode that does use the command line tools for the raw work.
