Hey guys, new to the boards =)
Question, The fan that is cooling off the Nvidia chip (chipset fan? the little one in the middle) on my Leadtek board makes alot of noise when I turn on the comp, and then goes away after 20 - 30 seconds. I was wondering whats a good fan to replace it with? or would just taking it off cleaning it up and putting some 3-in-1 oil quiet it down? Is it worth trying to fix or just easier to replace?
Again, the board is a Leadtek K7NCR18G-Pro, Link
Thanks in advance for you help =)
KP
KP
