Replacement bezels -- where??
kevinpray
75
Hi all,
I am looking to replace some beige bezels for an internal 250 IDE zip drive and 2 Samsung optical drives. I know that I can use vinyl dye on them, but I'd like to try to get "official" black ones.
Does anyone know where I could buy them?
Thanks in advance,
Kevin
Chucko
486
I used to feel the same way about black bezels. I always paid the premium (10 - 20 bucks more) to get a drive with black bezels. Then I bought my first can of vinyl dye and I WILL NEVER PAY MORE AGAIN. The vinyl dye looks great. Directron as mentioned earlier will paint your drives with dye for like 20 bucks. I think you may want to try harddrive.com also.
If you have an old cdrom sitting around go buy a can of vinyl dye and try it. Don't touch the bezel until the dye dries.
LOOKS GREAT
Thanks
Chucko
