Hi,
EDIT: I think I have located the area of the issue. Each time I bend the motherboard a little bit or pressing the CMOS battery on its seat, the computer boots but doesn't recognize the hard drive (or detected the HD with corrupted chars ex: MaHt0r instead of Maxtor.Not sure whats going on but it definitely not the CPU
I am trying to fix an unstable computer. Although not perfect but the computer was working. The computer hangs when running Prime95 for 10 to 30 minutes, probably due to overheating, so I decided to swap the CPU cooler by a better one. Now when I boot, the screen is totally blank. Either with the onboard video or with an external AGP card.
The changes I have notice after the change of the CPU cooler are:
- HD led is always on
- no beep when boot
- video totally blank (when VGA unplug the screen flashes "No Signal", when plugged in, there is simply a blank screen)
NOTE 1:
- all fans, lights seems to be working OK.
- also tried with another working PSU, same issues.
- Monitor working OK with another computer
- If I stop the CPU fan, the heat sink warms up. So may be this indicates that CPU is OK?
NOTE 2: I might have done something dangerous, when I cleaned the CPU of the previous thermal grease. There was some spill under the golden pins that I have clean off (using nail polish remover). I left some tissu dust on the CPU pin grid (motherboard side) and brushed off with a tooth brush. Then I put CPU back and assembled the cooler.
Question: Is the behavior above consistent with a bad mounting of the CPU?
Detail hardware:
The motherboard is Biostar P4M800Pro-M7 http://www.biostar-usa.com/mbdetails.asp?model=p4m80-m7
The CPU is D830, 90 nm, 130 W http://processorfinder.intel.com/details.aspx?sSpec=SL8CN
1 GB module, Memtest86+ v2.11 OK (4 passes successful)
PSU: Antec True power 480
- no beep when boot
NOTE 1:
Detail hardware:
