replace water heater, how much is a fair price on labor charge
rml
15,836
40 or 50 gallon, inside garage, electric, replace existing one with a new one.
Any one knows the average labor charge for this job?
thanks
rml
slag
10,473
For a neighborly friend/handyman, I'd say $50-$75.00 or so.
Its about a 2-3 hours job to turn off the gas or unplug the power, drain the old one, unhook the fittings, remove it, bring in a new one, hook everything up, test for leaks, sweat the dielectric unions, fill it up, ensure it works, light pilot light if applicable, etc.
Sundog
12,342
Sears is like $200 or something like that. My FIL helped me replumb the water, gas and vent lines when we replaced ours.
slag
10,473
sears overcharges
Its not a hard job and should not take longer than 2-3 hours at most.
I can do it in about 45 mins and I'm just your normal average person.
@ $20/hour, thats $60.00 total.
I wouldn't pay more than $75.00 tops.
Sundog
12,342
Originally posted by: slag
sears overcharges
Who TH charges only $20 per hour. Good luck.
T2T III
sears overcharges
You're kidding, right? Do you think that someone would do the work for $60 and then have to take taxes out of it?
T2T III
OK, just ran some numbers through the National estimator software that I own. A 50 gallon electric water heater from A.O. Smith is as follows:
Part: 532.00
Labor: 218.00
Total: 750.00
onebeeer2many
90
Part: 532.00
Labor: 218.00
Total: 750.00
That is pretty accurate. I work at Home Depot and the install rate is about $250. The reason is you half to get permits in order to legally replace a water heater and the labor includes the permits. You of course can replace it your self for next to nothing but it wont be done leaglly. GL :beer:
tw1164
3,995
You need permits to replace a water heater? Check w/ your local utilites company, they may have a program in place.
Antisocial Virge
6,578
Water heater is a mini boiler. Electric is not bad but gas ones can turn a house into a crater. Each cubic foot of water can become 1600 cubic feet of steam, with that expansion..boom. Real boilers that I have to watch are even worse.
T2T III
Part: 532.00
Labor: 218.00
Total: 750.00
I should have also pointed out that the rates I've posted are install rates. Additional amounts could be charged for disposal of the old water heater. Also, the rates don't include company profit and overhead - which are both legitimate charges.
Doggiedog
12,780
You need permits to put a freakin nail in the wall in my Nazi town.
sharkeeper
10,886
Lo and behold the BLEVE!
Even electric with a 4.5kW element stuck on and a missing TP valve (meaning pipe plug put in place! Yes I've seen that!) is quite the show.
Cheers!
TechnoKid
5,575
heh...way to bump an OLD thread:p, but i was wondering if anyone here knew where to get new anode rods for a rheem fury gas water heater, 40 gallon. I have limited space above the heater, so I'd need a segmented one, which leads me to say I'd have to cut the old one out in pieces, unless I want to unstrap the heater from the earthquake strap, disconnect the gas and water and vent lines, then tilt the heater.
Gonna do some maintenece on the water heater today (drain tank), and I might take a look at the anode if I can muster it off.
pancho619
2,467
My dad's a plumber, his company charges $150 to replace a water heater. A little more if it's a higher capacity heater or the area is hard to reach.
Doh...didn't read the date of the thread when I replied.
Ask at your local hardware supply store, like Lowe's, Home Depot or DIY.
