- Jul 11, 2001
- 41,361
- 10,480
- 136
My neighbor is married, has a couple young kids. They just replaced their Whirlpool washer and drier with bigger ones ("we do a lot of laundry," she said), at least one of which is Samsung. I think the replacements are unmatched but they put them in stacked (I witnessed that yesterday, pros installing them with brackets). They bought their slightly used machines off Craigslist from people who were moving. The neighbors asked me if I wanted the old Whirlpools, which were stacked.
I'd thought for years that a front loader would be good, that it probably gets clothes cleaner with the tumbling action instead of the vertical agitator action of my old Kenmore washer. New front loaders seem to go for $1000, has been my impression, but I have never shopped for one. I got my washer and dryer used when some friends of my sister moved and got new washer/drier. They offered the used machines to me for $100 each and I took them up on it... at the time I was a laundromat user. It took me quite some time to get them out of my living room and into the laundry room and installed, but they have been great. This was ~15 years ago and I'm quite used to the machines. They are both Kenmore, and the top loader washer (with vertical agitator) has Low, Medium and High water levels. I almost never use High because I don't think it cleans as well. So I don't stack clothes that high that it would need that much water. I can actually do an in between load by choosing, say, High and then changing to Medium before the water gets much over Medium level, a cute trick. The water temperature can be either Cold, Medium or Hot. I can also change my water temperature because I have a tankless water heater with a temperature selection module with 5 degree increments. The washing machine has hot and cold water inlets.
I live alone. I don't do a whole ton of laundry. I don't let it pile up, I do loads way before I need to. When I have something like enough laundry to do some, I do it. I rarely use the drier, actually. 95% of the time I hang out my laundry on lines I have rigged up in my back yard, just any old way I can. Attached to whatever, even tree limbs! If the weather doesn't dry my clothes enough, I will toss them in the drier. It happens, but overall I use the washer 10x more than the drier at least.
I gave my neighbor a $400 check yesterday after I was called by the wife asking me if I wanted them. I asked her what she thought was a fair price and she'd said $200 each? I said OK, went over there and witnessed the installation of the replacement machines and made out a check for her. Now, I'm wondering if I should back out and ask them to get rid of the machines some other way. I hadn't done any research, thought it through. The machines are sitting outside their door, presently.
I just did some online research on washing machines. One nice feature of top loaders is that you can toss stuff in after the cycle starts. I do that sometimes, plenty times. Can't with a front loader. The front loaders use less water... and electricity, I didn't know that. I was right that the front loaders get clothes cleaner, in general. Front loaders have a problem with mold and develop objectionable odors. I suppose you can fight that problem by cleaning the rubber seals occasionally, maybe wearing rubber gloves and using a bleach solution.
I don't know if you can do a smaller load in a front loader (i.e. use less water if you choose to do so), like I do with my top loader.
My machines are both Kenmore, but they don't match. Much different color, but that doesn't really bother me.
The Whirlpools can stack, not sure I'd do that. I have a laundry tub next to the washer that accepts water from the machine and drains to the drain pipe. It's there to prevent backup from a partially clogged drain, something that happened initially when I installed my present washer. Apparently, if I install these Whirlpool machines I would need to make more horizontal space, about 3-4 inches. I could do that by moving a cabinet that isn't affixed to anything. That would mean I'd have to reattach the dryer vent somehow, another complication, I suppose.
I would have to remove my machines and install the Whirlpools. Yeah, a hassle! And get rid of my old Kenmores! Another hassle!
I'm thinking maybe tell them I want the washer but will pass on the drier (ask for $200 back). Mine's a kind of yellow beige that doesn't match the white washers but I don't much care about that. I don't use a drier much. I don't mess with it's settings, have it set to on, close the door and punch a button and just remember to come back after X minutes and check the dryness. It has a bunch of fancy settings to count down, etc. but I don't mess with them.
I'm not sure what to do.
