Question Replace side panel with glass?
Jerethi
90
7
56
I have a Corsair Carbide 100R "Silent Edition" case, and am thinking about replacing the side panel with glass. I do see Amazon sells a 100R with a window side panel, but I'd have to purchase the whole unit. I've also checked Newegg and eBay and can't seem to find the side panel alone.
Does anyone have suggestions on how to procure a glass side panel only, or am I stuck having to get a whole new case? Thanks!
Reactions: robertstevenbk
Jimminy
503
188
Contact corsair and ask if they'll sell you the part.
If that fails, you could cut a window in your panel and take it to a glass shop and have them add the glass to it. Tell them what you're doing ... they may have ideas for even more bling.
BonzaiDuck
16,890
2,208
Some of us used to buy Lexan or Plexiglass for windows. A well-known modder's shop, forgot the name offhand but I think it's still in business, can sell you the rubber grommet you need for a hole of a certain size in sheet steel or aluminum. I suppose we're the "old generation" of case-modders.
I myself was curious about glass, for a project of my own. Does not glass contain lead? Does glass block wave energy, for instance radio waves, cosmic rays, EMP and other phenomena? Certainly, it let's light pass through it! Some cases like my Coolermaster Stacker 832 have windows, but with a perf-steel screen covering the hole, and one might assume that this acts as a sort of Faraday cage.
And I'm wondering about this, because removal of the perf-steel and replacing it with glass would make the PC prettier, provided that I don't need that perf-steel for air input and ventilation.
mindless1
8,863
1,820
^ Good idea. There's automotive gasket/whatever material that can be used to hold a sheet of material in sheetmetal.
I'd be inclined to use polycarbonate, because it can be worked with normal woodworking tools as long as you keep the speed (heat) down, and sanded and polished more easily than glass too if you want to add a fan hole. It should have a UV resistant coating or else it will gradually turn yellow over years, depending on rate of UV exposure. Starting with it yellow tinted would solve this, or smoke tint to a lesser extent.
Glass doesn't block EMI unless it's specially shielded for this purpose. Run the system with the side panel off to see if any emissions cause problems with your other equipment.
BonzaiDuck
16,890
2,208
It was always a question I had about replacing sheet steel or aluminum with a piece of plastic. But I had never encountered any problems with case-modding projects I've completed. For instance, I had a 1995 Compaq ProLiant server case -- bigger than a full-sized tower case. The outer side/top body panels were in two parts: a simple rectangular panel that popped off the left side of the case, and an L-shaped piece making up the top and right-side-panel. So I put a rectangular Lexan window with rounded corners in the left side-panel. Never had a problem of the PC's normal function, nor any noticeable interference with other hardware. But I always wondered about it.
The online Modder's shop I was thinking of was Mnpctech
The rubber grommet material I bought was meant for PC SECC sheet steel of the standard thickness. You had to make sure that the hole cut in the metal was everywhere 1/4" larger than the plastic panel you would install. You had to cut the rubber grommet to the precise length so that both ends mated perfectly once you had popped in the Lexan (or other type) window.
I was actually able to apply "mirror" automotive window film to my lexan window -- perfectly. That stuff is a bitch to use, even on glass car windows. It must not have bubbles; it must not have wrinkles. If done right, on either an automobile windows or something like the PC windows we're discussing, it appears to be part of the glass or plastic surface, as for instance a real glass mirror or smoke-tinted windows from the factory production line.
Oh, I think I found some pictures of the ProLiant case project. The second snap following this one shows the effect of having a mirror surface with lighting coming from the inside of the case. In future snaps of my computer-case projects, I should take more care to eliminate the "office clutter":
Reactions: CP5670 and meanoc
BonzaiDuck
16,890
2,208
Just buy a new case....
That, too, is good advice. As I implied, case-modding is one of the more ancient arts and practices of PC enthusiasts and veterans.
My project in the photos began with an old server case that a PC "Mom and Pop" store owner gave me for free. He was running a recycling operation out of his back door, and had a pile of cyber-junk, including cases. I didn't pay a dime for it. But the OP has a relatively new case -- a Corsair Carbide 100R. And he wants a window.
Suppose he does decide to cut a hole in his sidepanel. OK -- hopefully nothing lost there, but it's irreversible. He may spend a few bucks on Dremel cutting wheels or jigsaw blades. He cannot allow himself to screw this up. He should probably cover the case panel surface with tape, to avoid scratching it up.
But then, add a consideration for the next-door neighbors, who will have to suffer a bit for the clatter all this case modding can make. At least, that's a possible scenario. Unlikely that they would put a kibosh on the DIY project, because the disturbance may only last a few hours. But it is an aspect of the situation.
So, maybe ten bucks for tool parts, a couple hours of sweaty labor. Weigh that against just buying a new case that has a window in it.
At this point, I can't resist asking the question, since I posted my pictures. I wish I'd never let go of that Compaq DIY-mod, but my estranged brother last had it, and probably doesn't realize the value of what he has, so he may have discarded the whole enchilada. I won't go into detail about the various features besides the window, but I consider it a terrible loss.
So whaddya all think of my Compaq ProLiant mod? Is it cool? :p
sdifox
101,224
18,230
Working with sheet metal as a noob tends to get bloody.
BonzaiDuck
16,890
2,208
A profound "yes" to that. You have to watch out for those spiral-shaped metal trimmings, and the cuts leave very sharp edges. It takes some patience.
While I mourn the unnecessary loss of my ProLiant mod, the reason I was all goo-gah about my Coolermaster Stacker 832's in another thread derives from the extensive ventilation features that pre-empt much sheet-metal work. In fact, I've never so much as cut into any part of those cases. With the Stacker, one can simply block off the vents or use other means to seal the case when some of the features don't lend themselves to the case-preparation strategy.
Still, there was once a sort of renaissance of case-modding, evident here at Anandtech and in its archives. Veteran members will look at the little scars on their fingers and exclaim "I remember those days!"
Reactions: meanoc
Aug 16, 2021
134
It depends. When I started out and wanted to cut a hole for one more fan, I didn't even have proper tools, so I basically used sanding tip on Dremel to "cut" the fan hole and then 5 other holes for screws and cable. I didn't get hurt at all, but I didn't plan on how I will tidy up, so metal dust went on computer itself. I obviously tried to clean that up and nothing failed, so I guess that's a success. It's was a fun project, but I doubt its usefulness.
@Jerethi Anyway, depending on case modding it isn't worth it. Cheap cases often have thin metal, which bends easily and if you are adding fans, most likely you won't be able to mount it inside the case as inside of case is only made so big. The case may have some other size or other limitations, that would be annoying. Also some tools and materials may cost just as much as case, therefore it doesn't make financial sense to do that. If you want a window easy and cheaply, you will need to cut the side panel cleanly and you can buy acrylic sheet. For mounting, it's easiest to use a double sided tape to put it there. It should be decently sufficient ghetto mounting (double sided tape often is surprisingly strong, I bought some sketchy cheap double sided tape and it sticks very strongly). That's the only cheap and simple solution I know for adding a window. If you need to buy cutting tools (don't buy sheet metal scissors, they bend metal, it's hard to make straight cuts and they leave lots of sharp edges, they are just too rough) look at how much they cost, most likely it's not worth it to buy them just for one mod.
mindless1
8,863
1,820
^ I had a leg up in case mods because I'd worked HVAC rough installations, had the experience cutting and handling metal as well as the tools, but I still found the best tool for case mod cutouts was one I never used for HVAC, a jigsaw, with a fine toothed blade, then masking tape over the metal so the vibrations didn't case the jigsaw shoe to make marks in it.
Most of the cases I modded were reused OEM cases with at least 1.0mm thick sheetmetal, but sometimes when the sheetmetal was 0.8mm, I'd clamp a piece of wood to it for reinforcement while cutting, and/or screw it down to the wood in the area being cut out.
