- May 14, 2004
- 23
- 0
- 0
Hey guys...
I need some help solving this issue.
Been running windows xp on this hardware for a few months now and i just did a fresh format earlier today and put it up to SP2. Since then ive recieved 7 BSOD's with the same dump info. Could someone tell me what the info means and if possible a solution? Thanks.
* Bugcheck Analysis *
MACHINE_CHECK_EXCEPTION (9c)
A fatal Machine Check Exception has occurred.
KeBugCheckEx parameters;
x86 Processors
If the processor has ONLY MCE feature available (For example Intel
Pentium), the parameters are:
1 - Low 32 bits of P5_MC_TYPE MSR
2 - Address of MCA_EXCEPTION structure
3 - High 32 bits of P5_MC_ADDR MSR
4 - Low 32 bits of P5_MC_ADDR MSR
If the processor also has MCA feature available (For example Intel
Pentium Pro), the parameters are:
1 - Bank number
3 - High 32 bits of MCi_STATUS MSR for the MCA bank that had the error
4 - Low 32 bits of MCi_STATUS MSR for the MCA bank that had the error
IA64 Processors
1 - Bugcheck Type
1 - MCA_ASSERT
2 - MCA_GET_STATEINFO
SAL returned an error for SAL_GET_STATEINFO while processing MCA.
3 - MCA_CLEAR_STATEINFO
SAL returned an error for SAL_CLEAR_STATEINFO while processing MCA.
4 - MCA_FATAL
FW reported a fatal MCA.
5 - MCA_NONFATAL
SAL reported a recoverable MCA and we don't support currently
support recovery or SAL generated an MCA and then couldn't
produce an error record.
0xB - INIT_ASSERT
0xC - INIT_GET_STATEINFO
SAL returned an error for SAL_GET_STATEINFO while processing INIT event.
0xD - INIT_CLEAR_STATEINFO
SAL returned an error for SAL_CLEAR_STATEINFO while processing INIT event.
0xE - INIT_FATAL
Not used.
2 - Address of log
3 - Size of log
4 - Error code in the case of x_GET_STATEINFO or x_CLEAR_STATEINFO
Arguments:
Arg1: 00000004
Arg2: 80545ff0
Arg3: b2000000
Arg4: 00070f0f
Debugging Details:
BUGCHECK_STR: 0x9C_IA32_AuthenticAMD
MODULE_NAME: hardware
IMAGE_NAME: hardware
DEBUG_FLR_IMAGE_TIMESTAMP: 0
CUSTOMER_CRASH_COUNT: 4
DEFAULT_BUCKET_ID: COMMON_SYSTEM_FAULT
LAST_CONTROL_TRANSFER: from 806d38df to 804f8925
STACK_TEXT:
80545fc8 806d38df 0000009c 00000004 80545ff0 nt!KeBugCheckEx+0x1b
805460f4 00000000 00000000 00000000 00000000 hal!HalpMcaExceptionHandler+0xdd
FOLLOWUP_NAME: MachineOwner
STACK_COMMAND: kb
BUCKET_ID: 0x9C_IA32_AuthenticAMD
Followup: MachineOwner
x86 Processors
1 - Bank number
IA64 Processors
1 - Bugcheck Type
1 - MCA_ASSERT
4 - MCA_FATAL
5 - MCA_NONFATAL
0xB - INIT_ASSERT
0xE - INIT_FATAL
Not used.
2 - Address of log
3 - Size of log
Arguments:
Arg1: 00000004
Arg2: 80545ff0
Arg3: b2000000
Arg4: 00070f0f
Debugging Details:
STACK_TEXT:
STACK_COMMAND: kb
