- Aug 10, 2002
- 5,847
- 154
- 106
Have a bathroom floor in one of my rental properties that is failing. Tiles are popping and the grout is turning to dust. It was obviously put down wrong and needs to be re-done along with the rest of the bathroom. I don't have the funds at this moment to undertake another bathroom remodel but would like to repair (if possible).
Regarding the grout, I imagine I need to sand down the grout so I can re-apply more. I have a grout tool I can attach to my oscillating tool that can get down to the tile substrate. I imagine at that point after vacuuming up the dust i can mix up some more and reapply grout.
Regarding the popping tiles, I have to remove the tiles that are loose, sand away the mortar to get back down to a flat surface and either re-mortar or use some sort of adhesive (was thinking of liquid nails) to reinstall the tile.
I know the obvious choice would be to re-do the tile floor but budget cant allow that now. Im envisioning this fix I just described would need to last perhaps 2-4 years more until I get ready for another project.
What do you guys think? Does my plan sound good or do you have an alternative method?
