My friend's old 22 inch Samsung monitor went dark while he was killing zombies. I assumed the problem might be bad caps but a teardown revealed no damaged capacitors.
I think the next likely culprit would be the inverter transformer. I found the right part on ebay shown below. If you have done this repair before, I would appreciate advice on how to replace the part. It looks like there is a base that must be soldered and an insert that might plug in. Thanks.
http://www.ebay.com/itm/8TC0049901G...G-2243BW-/171052098321?_trksid=p2054897.l4275
