Repair acrylic and aluminum scratches?
stephenvv
23
Just finishing up a Lian-Li aquarium case with custom fans, lighting, sleeving etc.
Have one nasty 1 inch scratch on acrylic window and several small scratches on aluminum. Best repair methods?
0roo0roo
64,795
84
i've heard you can polish the windows using meguiars(sp)auto plastic polish. i'm not sure how u do aluminum since u'd have to go with the grain. or ud have to use fine sandpaper. using several different grades.
EdipisReks
2,722
i just wouldn't worry about it. scratches are bound to happen, no matter how careful you are.
toolfan
285
Take a look at Novus #2 polish. I ordered some of that to fix some light scratches on my case's door. Hasn't arrived yet so I don't know how well it works or how easy it is to use.
KouklatheCat
1,502
I got a scratch in my Lian-Li case, what ever you do DON'T, I repeat DON'T try to sand it out. I did and it screwed up my case. I ended up cutting the top of the case out and putting in a HUGE window to cover the scratch and sandpaper damage I caused.
Did I forget to mention DON'T use sandpaper?
stephenvv
23
I was nervous about sanding. I've ordering some appilques and decals.
Thanks for the warning and confirmation - much appreciated.
