Renegade box on workgroup (ICS Problem)
Rumble
Moderator - sorry bad connection posted 2x
I have a workstation that connects to the others in the group (sees hard drives ,files etc) but refuses to connect to internet with either auto detect ip settings or setting ip, subnets and gateways manually. All are win 2k on wifi 80211b . Connected to dsl thru a router with wifi access point plugged into the router. The other boxes connect no problem (I also tried this machine with a 10/100 hard connection with the same results. Is this a registry setting or perhaps a result of leftover setting from a previously installed and removed internet sharing software ? (All Aboard I Believe was the software)
Thanks, John in Miami
