RENAMED: Help with my receiver...speakers
longballmaniac
356
im just interested in why most people build these. im aware of its TIVO like abilities, but are these machines capable of replace A/V receivers altogether? im in the market for a home theater system (reciever, speakers) and i though id ask about these first.
i dont have an HDTV but my tv does have component inputs. is there a way to basically make the HTPC my receiever for things like my PS2 and dvd player to run through?
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
If you get unpowered speakers, you're still going to need a receiver or at least a multichannel amp to get the speakers running.
Pariah
7,357
20
In the most basic configurations, it can, but beyond that, no, it is not capable, and should not be used as a replacement for a reciever. A "true" HTPC should just be another component in ahome theater setup that connects to your reciever.
longballmaniac
356
gotcha thanks....im not planning on spending a great deal of money as im not audiophile at all.
im planning on getting this reciever http://www.ritebuys.com/viewitem.php?IndexID=13990&section=
and i know anandtech forum junkies will crucify me for saying but im looking to add a decent (not too terrible) set of speakers with a powered sub that isnt to expensive. talking 100-120 range. help would be much appreciated if you know of any. preferrably 6.1 setup to go with the receiver but a 5.1 should do for now.
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
You might be better off getting a Logitech z-5500 set or something on that budget.
longballmaniac
356
that wouldnt be a problem but those usually have the wrong type of connectors that im looking for. i was considering going over budget a bit and getting 3 pair of polk bookshelf speakers from outpost.com for like 50 a pair. only thing is then i have to find a power subwoofer and from what ive seen those are usually not to cheap.
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
Check out my Dayton sub thread in Hot Deals.
What kind of connections do you need?
longballmaniac
356
i shoulda given you the amazon link for the receiver theres a great pic of exactly the kind i need. i do know i need a powered sub and i dont know what they call the type of connection the other speakers need. its just where you connect the wires to terminals.
http://www.amazon.com/gp/product/B0007Y...nce&n=172282&%5Fencoding=UTF8&v=glance
about half way down the page is a great pic of the terminals. i'll take a link to yer hot deals if thats possible.
Mar 10, 2005
14,647
The speaker terminals on the reciever are banana plugs. You can insert bare wire and screw it down. But what's better is attaching a banana plug on each lead, and inserting the banana into the hole, for a tight, positive connection. No jokes, plz.
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
Those are binding posts.
I meant: What kind of inputs do you need on the receiver that a Logitech z-5500 set wouldn't offer?
Dayton subs
Pariah
7,357
20
With that budget, I would scrap the receiver idea, and just spend all $300 or so on the best set of PC speakers you can get in that range. You'll end up with a less versatile setup, but it will sound quite a bit better. Something like the Creative G500 Gigaworks or Klipsch Promedia Ultra's would work well.
longballmaniac
356
i bought a less versitile setup already and am returning it for the receiver speaker setup. im still fiddling with the money to get the best value and the best speakers and sub to go with that receiever.
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
You might want to concentrate the money on just a receiver and two speakers for now, adding to the system over time.
Mar 10, 2005
14,647
Going with a reciever and big boy speakers will always give better results, but at a higher price. Starting out with a stereo pair and adding more later is popular, and logical, way of building a system. I'm helping one of the guys at work with his system. He definately prefers the sound from his new pair of JBL's over his old 5.1 whatevers.
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
JBL northridge is pretty affordable too.
Something like a pair of factory refurb JBL E80s only runs a little over $200 shipped if you get a good auction.
ebay seller harmanaudio
Mar 10, 2005
14,647
Yup, I forced BB to audition the Northriges for him, and he took em home. They resist doing a decent setup unless you're shopping in the "Magnolia" high end section. Although I do like the Boston Acoustics they carry, the JBL's have great bang for the buck.
