Removing thermal pads from Heatsink
QuantumSlip
How do you go about removing it, and when do you get the stuff to remove it, if any? Screwdrivers dont work very well...
Tates
9,079
10
Screwdriver = potential scarring of the HS
Try using nail polish remover, then clean up with isopropyl alcohol.
chocoruacal
1,197
I scrape it off with a credit card, then clean the bottom up with q-tips and nail polish remover. Shouldn't be THAT hard to get off.
everman
11,288
Acetone works well (nail polish remover), also isopropyl alchahol. I do reccomend cleaning the acetone off with alchahol, especially on cpus, just to be safe. Soft plastic like a credit card helps, no hard metals.
akahai
1,230
I used GOOF OFF, which is like a glue or sticker remover, works pretty good, and follow by rubbing alcoholl.....
techietam
774
I second that. I tried to scrape my P4 HSF with some hard plastic and
it ruined alluminium pad that is under the thermal pad of P4 HSF
AMD might be a little more tolerent but stay away from any metal
no matter what :)
Wind
3,034
Originally posted by: QuantumSlip
i heard about that, I guess you get that at an automobile store or hardware?
Nail polist remover...can get it @ any cosmetic outlet ! & not screwdriver to scratch the bottom of the HS...please.
