I think I know the process I should take, but I want to run it by you guys to make sure. Here's the situation:
I have a 3-year-old XP Pro SP2 system that is going to be replaced by a new Vista Ultimate system I am building, as my primary system. I want to do two things to the old XP Pro system: (1) keep XP on it, just in case, and (2) install the new Windows Home Server on it.
First of all, I don't even know if I can dual-boot between Home Server and XP, but I'll cross that bridge later (does anyone know if this can be done?). The primary use of the old system wold be to run Home Server, as I think its hardware has enough oomph to run Home Server (Intel 925XCV mobo, 2 GB DDR2 RAM, Pentium 4 "Prescott" 3.4GHz CPU, ATI Radeon X1950 Pro w/256 MB memory).
But I may also want or need to use XP at some point, as some of my programs do not yet have Vista 64 versions. To simplify matters, I want to remove the two-disk RAID 0 array the XP system currently has as its system drive. It consists of two, 200 GB drives, of which only 60 GB is in use. So the entire software setup will fit on one of the 200 GB disks easily. These are all SATA I drives, BTW.
Here's the steps I think I should take to remove RAID but keep the current software setup unchanged--please tell me if I am correct:
SCENARIO #1:
1) Do a disk cleanup, removing all Temp files, Temporary Internet Files, etc.
2) Create a good backup. Actually, I will create two backups: a disk image using Norton Ghost, and a second using good old Windows Backup. I have two other large hard drives in my system, so I can store the backups on one of them (which is what I do now anyway)
3) Uninstall the Windows/Intel RAID drivers, and go into the system BIOS to disable RAID.
4) Boot from the Ghost CD, and restore the system image I made in Step #2 to just a single disk. This is where it gets a little confusing for me: since I can't un-RAID the system before I make the backups, the backups will have the RAID drivers and RAID configured. Will those drivers being present in the resored backup image cause problems?
I also have an alternative scenario. This is going to seem a little goofy, but follow along to the end, so you can see where I'm going.
SCENARIO #2:
1) Do steps #1 and #2 above.
2) Using Ghost, instead of backing up the RAID array to create a drive image, I would use Ghost's ability to Copy the drive to another drive. I have two other drives in my system, both of them 300 GB SATA I drives, so I can use one as the "cloned" drive.
3) This is the goofy part: as I mentioned, the RAID drives are 200 GB each. The other two drives are 300 GB each. I want to keep the 300 GB drives free, to use for Windows Home Server backups, media storage and serving, etc. So I will want both of the 300 GB drives clean. That means I first set the "cloned" 300 GB drive as the boot drive, boot up (hopefully after all this, it will), then again use Ghost to clone the files on the 300 GB drive back to one of the 200 GB drives.
I know, it sounds goofy as hell. But I want to keep the bigger drives open for server stuff. Also, it makes more sense to me to keep the OS and applications on the smaller drives, as I will not be adding more apps to them. I will then use the second 200 GB drive to install Windows Home Server.
I know this got confusing, so let me recap. Here's how I want the system to look when I'm done:
Disk #1 (200 GB): Windows Home Server
Disk #2 (200 GB): Windows XP Pro (current installation)
Disk #3 (300 GB): Server storage and backup
Disk #4 (300 GB): Server storage and backup
So which scenario should I use? Scenario #1, w/the Ghost disk image; or Scenario #2, w/cloning the disks back and forth? My gut says #2, even tho it seems goofier, simply because so much can happen during a backup--disk image or Windows Backup.
But I want to get you guys's opinion on which way you think I should go?
SCENARIO #1:
SCENARIO #2:
