i posted a message seeking opinions about what the fastest FANLESS video card is a couple of days ago and one person suggested that i could simply remove fan from radeon all-in-wonder.
i did a little research and found out that radeon AIW is clocked
lower than regular redeon. this in turn might eliminate the need
for fan since it's likely to generate less heat.
but i'm not sure... i mean the fan is there for some reason, right?
what do you think? would it be safe to remove fan from AIW?
i usually keep my pc on ALL THE TIME. but i use intel p-3 and the temp. inside my pc is reasonable...
