Removing cable from a patch panel
WobbleWobble
4,867
What's the proper way to remove punched down cable from a patch panel? Do you just pull the cable out or do you need a special tool?
I do have a simple impact punch down tool.
Thanks!
seepy83
2,132
Just pull it out. If you're planning on using that same port on the patch panel again, check to make sure there is no wire casing left behind and obstructing where the conductors need to get punched down.
RadiclDreamer
8,622
40
There are small hook tools for doing it, but if you are cafeful you can pull them out without issue.
ScottMac
Moderator<br>Networking<br>Elite member
Mar 19, 2001
5,471
The small hook tool is called a "spudger."
http://en.wikipedia.org/wiki/Spudger
You have to be very careful pulling the wires out, and using needle nose pliers or (ideally, a spudger) makes it easier to pull the wires straight up in the groove, reducing the chances of bending the insulation displacing blades. If you screw up the alignment of the blades, you risk a flaky connection (translates to potentially hours of gut-wrenching intermittent problems).
Also remember to use the "low" punch setting. Most modern panels and punch components do not handle the "high" punch power settings well... especially if your a "serial puncher " (three or four punches per connection ... bang, bang, bang, bang ... all on the same terminal).
FWIW
WobbleWobble
4,867
Thanks for the answers guys.
And good tip on the low punch setting. Mine is adjustable and I couldn't find any references on which setting I should use.
RadiclDreamer
8,622
40
FWIW
Thanks mac, never knew what they were called but have been using them for a decade or more
