remove front door on antec super lanboy?
pctwo
397
I want to remove the front door of my antec super lanboy. But I don't want to force it and break it, in cae I decide later to put on back on, or to sell it. Has anyone done this, non-destructively?
GalvanizedYankee
6,986
Hey!! It's an Antec, the door will fall off real soon :p
J/K. Antec should have a mechanical drawing in pdf. Download it, them blow it up.
Should be real simple to see. Zap might be along if no one really knows before he
gets here.
...Galvanized
pctwo
397
thanks, I downloaded the mechanical drawing, and it doesn't even show the front door separate from the front assembly, so there's no way to tell from that. hope someone else knows.
and this thing ain't coming off by itself, trust me :)
SparkyJJO
13,357
7
My old antec case - huge heavy beast that had 80mm fans everywhere - had a little clip on the top hinge that you'd push down to remove the door. It wasn't obvious, but if you looked closely you could see the "split" in the plastic at the hole.
I don't know if the lanboy case is the same or not (probably not)
