- Jan 3, 2001
- 232
- 0
- 0
GAH!!
I bought one of those removable hard drive rack setups and have it installed. Well, its not working like I'd hoped. I was hoping that on startup and restart of my system that it would be recognized. Instead, its really on and off, and I can only get it to work if I mess around when I turn the key during bootup.
Some things to note is that its plugged in to a RAID IDE in my KT7A-RAID, its a brand new 60GB Western Digital 5400rpm, and I'm using Windows XP Pro.
Most of the times when I have it plugged in and running, it won't detect by the RAID bios and the XP startup will hang when its doing its "blue status bar thingy" as it goes back and forth...it starts to fade in, then it'll stop. Then after like 2 mins, it'll go into windows, but my drive still isn't detected.
Can any one tell me what's going on? THANKS!!!!
