Remotely Control Power Strip Outlets?
ElectroPulse
26
Hello, all!
I'm currently looking around to see if I can find a good, inexpensive power strip that I can control through the network or over the Internet.
I ran across this (http://www.digital-loggers.com/lpc.html), but am wondering if there is anything that costs less (yes, it is a good price as it is), and perhaps supports SSH.
Another thing: Does the above power strip (and other similar ones) physically disconnect the power from the device? Like, if lightning were to hit nearby, could the device plugged into it get fried? (aside from through the ethernet cable)
The reasons I am wanting to get one: 1. To remotely disconnect power from a device (once I have turned it off through rdp or vnc) in the event of an electrical storm. 2. I normally leave my computer off, and the UPS it is connected to switched off (because of not having the ability mentioned in 1), so I would like the ability to turn on the power strip, then use WoL to start up my computer (in case I need to pull a file off my computer).
Thanks!
P.S. On a side note, do APC UPSs physically disconnect power from the devices when turned off? (as in, actually break the connection by moving two wires apart or something).
mfenn
22,400
www.mfenn.com
That power strip you have found is super cheap for a remotely switched PDU, especially one with individual outlet control. I'd jump on it.
To answer your question, yes the power strip physically disconnects the power from the device via a relay. While you could use a triac to accomplish the same thing, a relay is cheaper. Now, depending on how far apart the relay's terminals are, it is conceivable that a powerful enough strike could still bridge the gap. That's unlikely as long as the PDU is well grounded.
Don't forget that you still need power in order to actually reach the device remotely!
ElectroPulse
26
Thanks for the reply!
I'm thinking about it... Still not 100% sure that I am willing to drop 100+ bucks on it, since it isn't entirely essential (getting ready to head off to college, so am going to have other expenses). I'll keep looking around :)
Anyone know of one that's even cheaper? (I haven't run across one yet... Not sure that I will).
