Remote Starter for 1998 4Runner: Drawbacks?
aic
1,094
I will have a local shop recommended by my dealer to install a $259 Pursuit series APR0 9175FT4 remote starter with FOB.
What are the drawbacks or any tips I should consider?
I have 1998 Limited with V6.
Thanks.
StageLeft
70,150
That seems a farking lot of money. Most places in Nova scotia, Canada do it for $100-150 installed - and that's in CAN dollars. What's so special about this pursuit thing. Does it start the car faster? :p
aic
1,094
Yes, it costs $259. Sounds like I should price check some other places?
StageLeft
70,150
<< He never said it costs $259 to install the remote starter. >>
What? I can get one in canada for $150 installed - that includes starter and installation. $260 for starter plus installation seems like your money is burning a hole in your pocket.
StageLeft
70,150
<< So say I drive a stick and I park it in neutral.. can I still use this? >>
they do work for people with manuals yep.
thereds
7,886
Good Question. I've also wondered if it worked on manual cars as I own a stick. Question is, how does it work on a stick? Assuming that the clutch needs to be depressed for all stick shift cars, how does the remote starter bypass this. Does it cost more to install it on a manual car as opposed to an automatic car?
flot
3,197
You rarely want to install a remote starter on a manual transmission car. Too dangerous, or too expensive to install all the safety overrides/sensors you'd need to make sure it worked.
Besides, most manual transmission owners are used to parking their car in gear. Aren't you going to feel like a dumbass when you do it out of habit one day, then walk out to your car, hit the remote start button - and watch the car jump over a parking block into a ditch?
I have one on my automatic car, and it's fantastic. $259 sounds like a good deal to me - but maybe it's a much more common thing in canada (in colder areas?)
