- Feb 14, 2004
- 52,488
- 7,703
- 136
My car (base 2014 Kia Soul) has power locks, but does not have remote keyless entry. I'd like to add remote keyless entry and I'm considering remote start as part of the package, but it's a stick-shift transmission. I have mixed feelings on this. I know it's possible; in fact, Best Buy even offers it:
Some additional reading here:
http://www.mobileedgeonline.com/can-i-get-a-remote-car-starter-on-a-manual-transmission/
My only concern would be about safety. My buddy's dad had remote start in his manual car, but would always forget to leave it in neutral. He lost his keys once - someone found them in the parking lot and starting pressing buttons to see which car it belonged to and accidentally hit the start button, causing the car to drive forward (since it was in gear) and crash (no one was hurt, fortunately).
The newer systems have extra security features, including e-brake detection. The Compustar system recommended by the Mobile Edge website also has some additional protection features. They have the following procedure to ensure safety:
1. Parking:
a. Park the car
b. Pull the e-brake up
c. Press the Start button on the remote starter
d. Turn the car off (car remains running)
e. Get out & shut the door (car turns off)
2. Starting: Press the Start button on the remote starter
There is a wire on the e-brake that tells the system that the brake is up, so that's step one. Step two is for you to activate the system by pressing the Start button before you turn off the car. Then you shut the car off, but it remains running. Then, when you shut the door, the car turns off. Now the car knows that both the e-brake is up and the car is in neutral, because if you had gotten out with the car running in gear, it would have bucked & shut off the engine.
The car will now start via remote unless someone has opened the door, because opening the door means that the gear may have been engaged since the system detected the proper exit sequence. Sounds like a lot of stuff, but all it means is that you press the button on the keyfob before you shut the car off & get out, and that you leave it in neutral. Directed has a similar idea: (page 18)
http://www.directeddealers.com/manuals/OG/Viper/G4102V_2009_08web.pdf
1. Park & leave engine on
2. Set the parking brake
3. Release the foot brake
4. Within 20 seconds of foot brake release (you can press & release anytime), press any button on the remote & the car's lights will flash 5 times
5. Turn off & remove the key (engine remains running)
6. Exit the vehicle, close all doors, lock the doors
7. Engine wil turn off after a few seconds
8. Car will now remote start unless a door is opened before the next activation
That seems fairly safe to me. Also, it's a new car, so the e-brake is in good condition. I would be more concerned about parking on a hill or grade in neutral with only the e-brake activated & then doing remote start. I'm looking at 3 systems right now:
1. Directed (Viper/Python)
2. Compustar
3. Digital Guard Dawg
Directed systems can be installed at Best Buy & other local electronics retailers, so that's pretty easy to find. Compustar has a bunch of installers in my area. Digital Guard Dawg would be more of a DIY project unless I paid an installer to handle it, but they offer some additional nice features:
1. Pushbutton start
2. RFID smartkey (like Nissan - auto-locks & unlocks)
Directed has some nice features as well:
1. Smartphone support:
a. Nice if you lose your keys
b. VERY nice if you lock them in the car
c. Can remote start from anywhere with a 3G/Wifi signal (don't have to go to a window & aim)
2. 2-way keyfob system
3. GPS tracking via the 3G system (in case it gets stolen)
Lots of options. Seems a little risky though, especially if you're on a grade. Wondering what everyone thinks of this. I think it would be cool to have a combination of a Digital Guard Dawg pushbutton start & a Directed Smartphone/2-way keyfob system to add keyless entry & remote start. The pushbutton kit is $300 (or $350 for the passive card) system, but for the price I could live with a key, haha. The Viper system from Best Buy is $600 installed:
http://www.bestbuy.com/site/viper-vs...202700050022.p
More details here:
http://www.viper.com/smartstart/product/vss5000/viper-smartstart-security-and-remote-start-system
That includes:
1. Full kit
2. Installation
3. 2-way SmartStart module
4. Remote start system
5. 1-way Keyfob
Assuming it's plug & play with my power lock system (which doesn't include an existing keyfob), that would add:
1. Remote start
2. Keyless entry via keyfob
3. Keyless entry via smartphone
Somewhat expensive for the Best Buy package, but $600 includes all of that plus installation. It was 5F this morning and I don't have a garage, so it sure would have been nice to have today! I would probably upgrade to the 2-way remote: (1-mile range with command confirmation, but this LED doesn't require charging like the LCD model does)
http://www.viper.com/car/remotestart/product/4806v/viper-led-2-way-remote-start-system
So that would add keyless entry, let me use my iPhone as a backup keyfob, and upgrade to remote start. I think on flat parking spaces, this system would work pretty well (neutral, parking brake, safety procedure). I don't know if I'd do remote start if I was parked on a hill, but I rarely do that. Yay/nay?
Can you install a remote start in a vehicle with manual transmission?
Yes. Some vehicles with manual transmission can get a remote start system installed. However, there are vehicles with manual transmission that will not accept a remote start system. Contact your local Best Buy at 1-888-BestBuy to talk to a certified Autotech about your specific make and model.
1. Parking:
a. Park the car
2. Compustar
1. Pushbutton start
More details here:
That includes:
1. Full kit
2. Installation
5. 1-way Keyfob
1. Remote start
